TwinTurbo.NET: Nissan 300ZX forum - the TT oil pump will flow more than an NA.
apudapus
on January 10, 2008 at 7:00 PM
oil pump ?
posted by force1
on January 10, 2008 at 05:53 PM
get a new one from one of the forum sponsors. also, you will have to remove the oil pickup tube (and oil pan and one or both of the turbos) to get the oil pump out.
oil pump ?
force1
17:53:14 01/10/08
I would go new.
nemo1080
18:19:29 01/10/08
the TT oil pump will flow more than an NA. -
apudapus
19:00:15 01/10/08
prob be easier for him if he just pulls motor? (n/m)
nemo1080
19:34:29 01/10/08
A search showed that the oil pump can be replaced
ThunderZ
20:36:32 01/10/08
Mmm 30 min to set the jacks maybe :/
zcar4me
21:00:21 01/10/08
I'm not sure how most people can pull the oil pan so easily
TTFairladyZ
23:37:16 01/10/08
2nd.
apudapus
18:17:51 01/11/08
i would do it this way, too (pulling the motor) (n/m)
apudapus
18:18:44 01/11/08
You can not use a NA pump on a TT - they are not the same. (n/m)
19:24:45 01/10/08
can you get a tig welder on it?save lots of work
mossyoak
21:24:36 01/10/08
JB weld (n/m)
AZHeat
21:36:10 01/10/08
2nd. worth a shot. if it works, you saved a ton of
nemo1080
22:05:34 01/10/08
don't think I would risk it on such an important part... (n/m)
Waco300zx(DFW)
09:35:43 01/11/08
im done that before, good luck
Halo Z
23:24:58 01/10/08
lucky for me, the motor is out. i am doing a swap
force1
03:17:27 01/11/08
tell me what not to do, so I dont break mine.
mossyoak
14:20:52 01/11/08
well, first off, be patient
force1
18:03:19 01/11/08
